PCB assembly discussion
Re: PCB assembly discussion
Yes, or less depending on the temperature ranges you want to display. The short pin at the front is counted as pin 1, from there it's %2, C14, K10 and the anode is pin 8.
Which ir led goes with the metal sensor? I need to know the wavelength value...
it's the one WITHOUT brown tape, 940nm.
