1 - Relay kit contents
Posted: Fri Dec 01, 2017 6:32 am
This covers the original Kickstarter 'Relay' 5-tube clock module which as supplied can be used with IN-14 and IN-8-2 nixies. Other similar sized tubes will laso work with varying modifications.
You should have received the following:
- 1x Bag1 - a pink electrostatic safe bag with all of the electronic components.
1x Bag2 - The paxolin case pieces
1x Levitating magnet
1x IN-19 nixie
You may also have received 4x IN-14 or IN-8-2 nixies if the version you bought included them.
Re: Relay kit contents
Posted: Fri Dec 01, 2017 7:48 am
The case 'Bag2' contains:
- 1x PCB
1x Base panel, 0.8mm laminate
1x Notched loop, 0.8mm laminate
2x 'narrow shaped' loops, 1.5mm laminate
1x 'wide shaped' loop, 1.5mm laminate
2x 'narrow plain' loops, 1.5mm laminate
3x 'wide plain' loops, 1.5mm laminate
1x Top panel, 1.5mm laminate
Posted: Fri Dec 01, 2017 7:49 am
The Relay component Bag1 packing list is:
- R1,2,4,5,7,8,11,12,14,15
750k 0603 x10
R3,6,9,13,17
10k 0603 x5
R16
91R 0603 x1
rx,y
470r 0603 x2
C1,2,3,4,5
2u2 16/25V X7R 1206 x5
C6,7,8,9,10,11,12,13,14
100n 50V X7R 0603/0805 x9
C15,21
1n 50V 5% C0G 0805 x2
C16 x3
4n7 50V 5% C0G 1206 x3
C17,18
100n 200V X7R 1206 x2
D1
3V9 Zener 500mW MELF x1
D2,6,7,10,11,12,13,14,15,16,17,18,19
LL148 LL44148 MELF x13
D3,4,5
BAV99 SOT23 x3
D8,9
75V 500mW Zener MELF x2
LED1,2,3,4,5,6,7
WS2812B RGB LED 4 pin x7
T1,2,3,4,5,6,7,8,9,10
BSS123 SOT23 x10
T11,13,15,17,19
MMBTA92 SOT23 x5
T12,14,16,18,20
MMBTA42 SOT23 x5
IC1
PIC x1
IC2
CD4028B SOIC16 x1
IR receiver
CHOD x1
Wire
0.20mm copper 50 turns x1
Solder
0.47mm 10 turns x1
Pins
40x1 strip x1.5 (60 pins)
Nixie sockets x5
Sticky pads x3
M3x20 CS bolt x2
M3 brass nut x2
M3 Brass washer x2
Note some of the component sizes may differ slightly, if so it'll be mentioned during the assembly.
