my relay (kit assembled by me) has a distinct list to one side. I'd say one end is about 10 mm closer to the base than the other, where should I be looking to fix this?
Cheers,
Robin.
Not floating level
Re: Not floating level
Rotate the top magnet, apply balancing weights, at worst I'll have to send a new levitation assembly as the manufacturer doesn't guarantee they will be level. Was the magnet on its own level? if so it will be a weight issue.
