Tony,
I have used small #6 ring terminals to attach the copper wire to the screws that secure the coil to the main board. Do you think they will interfere with making of the case? Any reason why I should not use these terminals? I plan to substitute with insulated terminals. I have attached a photo
phil
Ring Terminals
Ring Terminals
- photo of ring terminals
- Board Coil Ring Terminal.jpg (197.73 KiB) Viewed 22257 times
Re: Ring Terminals
No reason at all, it makes a very neat finish.
