Really all that's needed is sand the top flat (wet sanding is best). Round off the edges and engrave the top if you want or leave it as is - then colour the piece with gold/silver paint/coloured wax/whatever you want to use. Drop the piece PCB assembly in and use a little glue (from the top) to hold it in place. Push in the nixie.
I used hot melt engravers wax for the ready built board pieces but never again - too many burned fingers.
Piece base case
Assembly instructions for the V1 chessboard.
Return to “Assembly instructions”
Jump to
- Timelord Kits
- ↳ Plasma button of Doooom
- ↳ Nixie thermometer V1
- ↳ Assembly instructions for the Thinkgeek nixie thermometer
- ↳ Nixie chessboards
- ↳ Nixie Chessboard V1
- ↳ Nixie Chessboard V1.5
- ↳ Nixie Chessboard V1.6
- ↳ Assembly Instructions
- ↳ Nixie OXO board V1
- ↳ OXO board assembly instructions
- ↳ 5-tube nixie clocks
- ↳ IN-14 V1 5-tube nixie clock
- ↳ Assembly Instructions for the IN-14 5-tube clock
- ↳ Mad science Nixie clock - TBA
- ↳ The Coppertop IN-8-2 kit
- ↳ Assembly instructions for the Coppertop clock kit
- ↳ The Cylinder IN-12 V3 Clock
- ↳ Assembly instructions for the Cylinder V3 clock kit
- ↳ Time Flies
- ↳ Setup and operating help
- ↳ Assembly instructions - kit version
- ↳ 1 - GPS mouse
- ↳ 2 - Power controller
- ↳ 3 - Levitation base
- ↳ 4 - Clock modules
- ↳ Beacon
- ↳ Relay 5-tube
- General discussion
- ↳ General discussion
- ↳ Gallery
