Piece base PCB - SMD version
Posted: Sun Feb 02, 2014 5:01 am
For the pre-assembled piece boards, cut 64 short pieces of thin 'hookup wire', about 2.5-3cm long. Strip and tin each end then solder one of the above trimmed socket pins onto one end of each of the 64 wires.
Place the piece PCB with the 2 large solder pads at about 10 and 2 o'clock then solder one wire to each of the 2 pads. Repeat for all 32 PCBs, using your 64 wires.
Connect the wire from the left pad to the tube anode (IN-7 pin2, IN15 pin1) and the wire from the right pad to the required tube cathode, as in the instructions below.
This method makes it much easier to assemble rather than having to try and hold the pins onto the PCB in the correct position and vertacal whilst soldering them.
Original instructions:
For this you will need the entire contents of BAG 3 (SMD components and BAG 4 (Piece PCBs) plus solder from BAG 5.
99x Diode packs - Three legged black rectangles with text etched on the top surface. These are polarised and must face the same way as in the photographs with the text facing up.
33x Glass Diodes - Copper-orange glass cylinders with a black band marking one end. These are polarised and must face the same way as in the photographs.
230x 0.1uF Capacitors - Beige rectangles with solder on either end, not polarised. Seven of these are used on each board.
33x 1nF Capacitors - Grey rectangles with solder on either end, not polarised. One of these is used on each board.
